lt500r wondering how they are supposed to run
Old 09-12-2002, 08:11 PM
Duneaddict's Avatar
Have you figured out the exhaust valve V8?
1st check: How's the spring look? If it's bent or looks bad, replace it!
2nd: Valve free and turns easy?
put the cap on the spring with no preload (note where the pointer is oriented) turn the spring/cap assembly 180 degrees COUNTERclockwise and lock it down.
Very easy adjustment. The valve will remain open until approx 4500 rpm.
Hope this helps
Old 09-12-2002, 09:44 PM
ben's Avatar
ben
ben is offline
v8vega350,,i have the same problem that you have but mine is on a lt 250 a went 1.25 over on my piston.the power valve rod don't go up at all.i adjusted the power valve by hand on the left side and it runs a little better but something its wrong.the power valve rod move freely.but i'm going to try the steps from duneadict.
Old 09-13-2002, 08:32 AM
v8vega350's Avatar
that i how it is adjusted but it is like it just cant push hard enough i can see the lever starting tp push up but it will only wiggle a little bit. i moves perfectly and after it is adjusted i can push it easy. do you know how much pressuer it is supposed to push with
whould this stop it from reving if it is not opening or will it just not make as much power
Old 09-13-2002, 07:49 PM
Mr350X's Avatar
It will still rev... but it wont make all the top end that it would if the valve were open.
  #15
Old 09-14-2002, 04:52 AM
ben's Avatar
ben
ben is offline
v8vega350,i live close to you,i can ride over your house and work with this togheter,if you have a some tools,if not i have plenty of tools at my house,you are welcome.my e-mail is bnarroyo@hotmail.com.plus i have acess to a dyno,when ever i want to.
  #16
Old 09-14-2002, 05:18 AM
v8vega350's Avatar
feel free to come over if your around the west hill of kent just let me know my email address is v8vega350@attbi.com
Hankey Pankey
05-01-2018 01:33 PM
Jenn1
09-08-2015 09:16 AM
Hankey Pankey
08-17-2015 05:01 PM
08-06-2015 11:49 AM
drewy2dope
Ask the Editor
11
07-31-2015 09:36 AM
Quick Reply: lt500r wondering how they are supposed to run
