~Tires~
Old Sep 18, 2002 | 08:59 PM
SuZuKiZ400RiDeR's Avatar
Will a different tire size change the gearing on a fourwheeler? If it does, than what is the ratio. Does anybody know a good tire for the Z400. Let me know what you think or know.
Thanks,
~Knowles~
Old Sep 18, 2002 | 09:16 PM
maddog56's Avatar
yes, depending on how much you change the tire size, it can affect the gearing.
i think that when you go down in tire size, the front sprocket gets a tooth or two.
the best tire depends on your riding. itp holeshots are great for most of your trail riding, but the maxxis razors are about the same and they are cheaper and last somewhat longer.
for sand, skat-track extremes, if you can afford them. definately a 10in wheel with a 20 or 22 in tire. otherwise, the haulers are great too. if you want to be able to turn in the sand, and you arent focused solely on drag performance, some sand devil or similar v-shaped paddles are good to go with.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
