quadracer 88?
Old Sep 21, 2002 | 10:01 PM
evhwg's Avatar
can someone run this # and tell me if it comes back as an suzuki quadracer 1988.
i also was looking on the engine for a serial # and couldnt find one. do they usually have one?
heres the frame serial # JSAAJ12A8J2102613
AND THE LAST QUESTION IS the quad vibrated like mad when i test drove it. my hands went numb from a little ride. it looks like a atv motor ,could the weight on the counterbalancer of fell off?
also read in another thread there stopping making trannys and one other thing for these quads is this true?
Old Sep 22, 2002 | 04:35 AM
chuck1221's Avatar
I don't know how to run the #'s but if it is a 250 quadracer and it vibrates alot you probably sheard the key on the counterbalancer. I wouldn't run it anymore till you get it fixed. to fix it take off the clutch cover after draining fluids, take off the clutch and clutch basket then remove the nut on the counterbalancer weight and pull it off. It that is the problem you should take off the mag cover and pull the shaft out to check for wear where the bearings and weight go. If the shaft is exisvly worn replace it, also check the bearings and if you just put a new balancer key in torque the nut down to specs with loctite. It greatly helps if you have a manual. Hope this helps.
I had this same problem on my 91' quadracer.
chuck
Old Sep 22, 2002 | 08:57 AM
GuyRaptor's Avatar
You said you were test riding this thing so I'm assuming you are looking at buying it. My advice, run fast and run far. There's plenty of other LT's out there.
Old Sep 22, 2002 | 10:27 AM
lt250r91's Avatar
First of it is a 88, I know this because the 10th digit is a J and the J's are the 88 models.
85= F
86= G
87= H
88= J
89= K
90= L
91= M
92= N
as for the vibration, I had a similar problem and mine was the motor mounts where broke. And other time it was the main bearings where out.
What chuck said could be true too.
Other thing it could be is that the main bearing seats are worn out causing the main bearing to move.
I would go with raptorguy on this go find a different one and stay clear of this one unless your willing to put so serious money into this one right off the bat.
Old Sep 22, 2002 | 12:09 PM
evhwg's Avatar
heheh i think i am going to run away from this one heheheh...the guy wanted 2800.00 for it heheheh what a POS.
i was just wondering what the prob would be for my mental notes.
thanks for the help
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
jfboy
Nov 8, 2000 07:06 AM
max250
Aug 8, 2000 09:58 PM
