LT 500 Rear Coil Rate???
Old Sep 22, 2002 | 10:30 PM
FrenchGuy's Avatar
On a 1988 LT500, Would any one Know the Stock Coil Rate???
I only weight about 165lb plus Gear. I Have Losen the coil all the way, Got the shock
rebuilt, change all Bearings and Seal, and still only sags down about 1/2" inch when
I sit on it. I think maybe some of the previous owner might of changed the coil to a heavier coil rate.
My last option is to gain a 100lb pounds or so...
Thank You !!!
Old Sep 22, 2002 | 11:15 PM
SaMs0n's Avatar
Well if you want to gain a 100 lbs, try eating a lot of fast food like MacDonalds or Burger King [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 23, 2002 | 08:03 AM
kevdawg's Avatar
Call a shop If your talking the pressure in the shock on my 88 LT250 its 143 psi
Old Sep 23, 2002 | 04:56 PM
VegasQuadracer's Avatar
I'm having the same problem with my Zilla. It actually pogo sticked me over the handlebars several months ago so it is a serious problem for me too. I'm getting mine rebuilt and revalved and should have it back any day now. I'll let you know if it improves anything. I asked the guy rebuilding it if I should get a new spring and he talked me out of it. They are not that expensive, around $100, and the manufacturer/dealer should know stock rates for comparison. If mine is still stiff after the rebuild I may replace mine as well. I'll re-post later.
STLyamwar
Jul 25, 2020 04:44 AM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
WesTech
11
Aug 11, 2015 07:55 AM
Sandman2.0
Jul 21, 2015 09:03 AM
rcappie4
Jul 10, 2015 04:54 PM
