NEED HELP BAD with carb and jetting for Z
Old Oct 4, 2002 | 08:34 PM
dunerunner026's Avatar
k i have a Z400 with no air box lid, ct full pipe ( no spark arrestor ). k&n filter, dyno jet kit with needle on third clip, 155 main ( biggest they have ) and a 25 pilot. im having some problems.
the bike seems to run fine but when i rev it up it sounds like its hesitating about 3/4 maybe or maybe a little after 1/2. when i stab the throttle real fast it will just die, or after i rev it up fast by holdint it open after i let off it will die?. it shouldnt do that should it?. i dont know whats wrong. also when im riding if im climbing a hill and hold it wide open then have to stop or slow down i pull in the clutch it will die also some time going down hill with the clutch in it will also.
i replaced my spark plug and the electrode was barley brown but it was real black all over everywhere else. it seems like im running rich. am i too rich on the midrange?? also when i put the airbox lid on i wont even go anywhere it burps and dies after i start to open it up.
thanks for the help
Old Oct 4, 2002 | 09:32 PM
thrshr's Avatar
when this happened to me i noticed that my choke was slightly closed (i must have accidentally hit it). after this incident, i have heard of someone say that the choke on theirs was misadjusted and it caused the same problem that i had. well, to make my answer short, make sure that your choke is fully open (check in the carb not on the lever). btw, 155 sounds abit small. you might wanna try a couple of sizes larger.
Old Oct 4, 2002 | 09:51 PM
im using the dynojet 155 which is the biggest there is.
Old Oct 4, 2002 | 10:03 PM
RaptorOwner's Avatar
I dont know if this will help but I got mine from Trinity with no lid and the alba k&n filter kit and run a 165.
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
