Zilla Electrical
Old Oct 9, 2002 | 08:01 AM
truckracer's Avatar
Default Zilla Electrical
Lights on the the Zilla are very dim at all RPM's so I pulled the Stator. Found the leads from the lighting coils taped together (sorta) with black tape (I just hate it when someone has butchered something before I get a chance to!), one lead actually was not connected. So, I thought as this point I would test the coils resistance, if they were the same I would make proper connections and put it back together. They did not test the same, not even close, one was 8 ohms the other 25 ohms.
At this point I decided to upgrade the coils, I checked out Mr Dunes setup adding a battery to the circuit. I called Ricky Stator, they told me I could buy a complete Stator wired for use with a battery but I couldn't buy just the coils setup the same way.
Anyone know an alternate way to run a small battery or capacitor on this type of electical circuit?
Thanks
Denny
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 9, 2002 | 03:47 PM
OutCast's Avatar
I haven't checked into being able to run any sort of capacitor, but I think it would be possible to run a regulator rectifier to get you DC to charge a battery. As for the capacitor, I think it could be done in series with a resistor on the AC side since lighting doesn't care if it is AC or DC on a 12v scale.
OutCast
88 LT500RJ
Old Oct 9, 2002 | 04:49 PM
JeremyKS's Avatar
While we are on the electrical topic does any body know another type of voltage regulator i could use besides a high dollar suzuki one. Mine went bad on the 500. Any ideas
Old Oct 10, 2002 | 01:52 AM
OutCast's Avatar
JeremyKS,
The only thing I could suggest is, you find a used one for sale. They sell them on ebay from time to time.
OutCast
88 LT500RJ
Old Oct 10, 2002 | 12:58 PM
quadzilla499's Avatar
I think I have a used voltage regulator I will sell. I will look tonight and see if I still have it.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sw00p
Sep 24, 2015 02:50 PM
