Hot Cams vs Stock Cams Dyno
Here we go boys. I was at Trinity last night and Harry helped me degree the intake cam. With about 5 degrees advanced, it went up to 48hp and gained more torque. I posted the dyno for this and just for fun I had Harry run a dyno sheet comparing the stock motor to where it is now. At the top end it is creating yes, 30 more hp than stock. I now have more torque than the motor had hp stock. Trinity Racing has the magic touch.
#15
WP,
When you talked about setting the cams 5 degrees more advanced. What you are doing is actually moving the centerlines of the lobes forward 5 degrees? Or did he stabilize the cam and rotate the crank forward 5 degrees? I'd be curious as to the exact centerline of the lobe now. Harry should know what I'm talking about if you don't. Thanks.
Tony
Tony
#16
We losened the two bolts, marked the cam to gear relationship, then bumped the cam lobes forward 5 degrees. We used a modified degree wheel to get the number. We may try more, but we need to check valve clearances first. We did all of this to gain more bottom end back. With the new ignition and these cams, it really revs out good, but I still need that holeshot power.
#17
#18
#19
WP,
I haven't had a lot of time to think about it yet. I have to tell you though, Harry is one smart cookie and a great engine builder. I'm kind of curious what 105/105 would be like on the Big Bores. 103 in seems pretty extreme to me personally, but like I said earlier, I don't get to play with any of the mod stuff. And with the seperation where it is at now seems a little odd too. Although we run 102 ex, 106 in on the YZ250F. Keep playing with it, Maybe try 106 in, 104 ex. Who knows.
Tony
Tony
#20
I will tear it apart tonight to inspect for any wear and for valve clearance. Then I will have Harry take a look to see what he thinks. By the way, I am thinking of putting a kick start on my bike to shave off 28 lbs. How hard is it to kick one of these over (or DRZ) without the decompression release?
