lt250r motor sawp question
Old Nov 5, 2002 | 06:34 PM
TomM's Avatar
Default lt250r motor sawp question
Would I have to modify anything to put a 87+ motor on a 1986 frame?
I just bought a 86 all stock. Ive seen 87+ motors for 300-400$. Thats not much $ per performance increase. Seems like the best place to start.
Old Nov 5, 2002 | 06:56 PM
dual-sporter's Avatar
yes, the tube on which the front motor mount is bolted to forks to go around the pipe in the later years,(your bike has the exhaust exit to the left of this frame tube) so the motor mounts up slightly different in the front and the pipe mounts up slightly different.
Old Nov 5, 2002 | 07:21 PM
TomM's Avatar
Do you know if the jug and head from my 86 motor would fit a 87+ motor?
It doesn't look hard to modify the mount, but I would rather not spend more $$ on a different pipe.
I know the 87+ has a power valve. Although I don't know what that is, it is probably on the jug/head. I could live without that though. I'm more concerned about the transmission.
Old Nov 6, 2002 | 06:03 AM
none of the parts swap between the earlier & later engines really. the powervalve on LT's changes the volume of the exhaust chamber to create more power on top & bottom.... the cylinders and bottom ends are completely different designs
Kyle5050
Dec 13, 2019 04:25 AM
ronnierhino06
Nov 9, 2015 12:56 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
