weak stator symptoms on zilla
Old Nov 5, 2002 | 09:55 PM
stormnorm's Avatar
Default weak stator symptoms on zilla
What would be some symptoms from a weak stator on a Zilla. My quad starts good, idles fine and runs very strong until about 3/4 where it starts to run rough and almost refuses to rev up higher. I put in a new rotor in July after the old one broke of and took along with it the small plastic tabs on the lighting and pick up coils. No wires were damaged except for those plastic tabs. Anyone know what a weak stator does???
Old Nov 6, 2002 | 12:01 AM
Mr350X's Avatar
Well, I cant really help you... but, after riding glamis all day long no knowing that my headlight was on, I went to ride saturday night over to comp and my light was really dim. Have any idea why? My lighting coils going weak?
Old Nov 6, 2002 | 08:42 AM
stormnorm's Avatar
Sounds like a bad voltage regulator. Anyone know about a bad stator and its symptoms???
Old Nov 6, 2002 | 09:15 AM
whatwasthat's Avatar
i dont know but it sounds like your fuel mixture is too lean or too rich
Old Nov 6, 2002 | 09:32 AM
donzilla's Avatar
if your bike starts it probably isnt the stator . it sounds more like main jet might be a little small not letting enough fuel through or the reeds . i thought my stator went bad on a dune trip but it was my reeds .
Old Nov 6, 2002 | 09:39 AM
truckracer's Avatar
On a Zilla there are three coils on the stator. 2 for lights, one for ignition. Since there is only one it's a deal where it either works or it doesn't. With that being said check your wiring over, pay particular attention to the grounds.
My lights were also very dim last trip out. Found one lighting coil bad (open winding). Replaced the coils with new ones (130 watt !) from Ricky Stator. $53.00 for the two coils. They also sell a complete stator assembly for around $130.00
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
