-Jetting Questions-
Old Dec 6, 2002 | 01:51 AM
llknowlesll's Avatar
Default -Jetting Questions-
I have a Z. I have a Yoshimura Slip-on and a K&N Airfilter. My airbox lid and snorkel are removed. I just can't get the jetting where I am happy with it. Besides changing the main jet what else is there to adjust. I know you can adjust the needle. What is the best way to go about this? Can somebody explain to me how to do this in a way that I can understand? I need help!!
llknowlesll
Old Dec 6, 2002 | 02:08 AM
BayouBlaster's Avatar
I have a jetting article I found in a magazine that explains jetting in plain English that a normal person can understand. If you want it emailed to ya, just let me know.
Old Dec 6, 2002 | 12:01 PM
absrio's Avatar
Are you using a stock needle or an aftermarket one the stock isnt really designed to be adjusted but can be done by adding washers on the aftermarket one there is a little clip on it with 5-6 grooves you move the clip to diffrent grooves to go from rich to lean
Old Dec 6, 2002 | 02:48 PM
FERRETWIGGLE's Avatar
April 2002 issue of Dirt Wheels has one of the best articles on carburator jetting I have come across, in their Hot Horsepower Tips colomn. It is also available on line at their website www.dirtwheelsmag.com
With a modified air box and Yosh slip-on you may end up with a 150-155 main jet, depending on the ambient air density of your area, among other things. You may also need to adjust or change the jet needle and/or the pilot fuel jet depending on how your quad runs in the mid range and/or down low (respectively)
FW
Old Dec 6, 2002 | 06:39 PM
That article in Dirt wheels is the one that I was talking about that I have scanned. It's pretty good.
Old Dec 6, 2002 | 08:38 PM
Thanks guyz. I called Yoshimura today and they got me fixed up. They are really helpful. Thanks for all the support and help that you have offered. I am now running a 150 main with the needle clip on the 4th groove up.
Thanks,
llknowlesll
WARRIOR360
Nov 26, 2008 02:06 PM
YAMAHARIDER703
Mar 12, 2008 12:17 AM
04BlasterRider
May 10, 2006 09:18 AM
Toyorider
Oct 3, 2005 08:51 PM
mikystyle
Jul 3, 2005 02:21 AM
