Eiger vs Wolverine in a drag...
Old Jan 23, 2003 | 09:52 AM
BigBearFX's Avatar
Default Eiger vs Wolverine in a drag...
Which would win in straight line?
Which would win on the trails?
i know i posted 2wice
Old Jan 23, 2003 | 10:40 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
I bet it will be very, very close.
The Eiger has the stronger and quicker reving engine but I'd guess that the Yamaha would win by a small amount. The Wolverine has a 100 pound weight advantage plus runs smaller tires. In a pure drag race I think that this would be enough to give the Wolverine the win.
Now, if you stuck some 23" tires on the Eiger I bet you'd see it pull ahead.
Interesting that what was (and still is) considered a "sport 4x4" is no longer very different from the current crop of "sport-utility" rides.
Jaybee
Old Jan 23, 2003 | 05:47 PM
BK's Avatar
BK
Been there, done that! I had a 2002 Eiger manual shift, and my brother a 2002 Wolverine. They are very close. My brother and I weigh about the same. The Eiger got a little jump off the line and they were even the rest of the way. Top speed seemed about the same. I started in 2nd gear because first is so low. If I had another gear I could have pulled away on top end because I was wound out. The Eiger motor is stronger, especially in the low and mid-range.
On the trails they are a good match as well. The Eiger doesn't have to shift as often but they move along at about the same pace. Wolverine may handle a little better but that is in part because of the bigger tires and a little extra weight. I would probably go with Eiger overall, due to its ability to do more work related duties without sacrificing the trail aspect. They are both good though.
suzuki230
Jul 8, 2016 10:03 AM
panicmanic
Dec 15, 2015 01:58 AM
baysport
Jul 23, 2015 11:37 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
