Zilla head gasket thickness?
Old Feb 11, 2003 | 12:21 PM
Duneaddict's Avatar
Default Zilla head gasket thickness?
Gotta have high temp O-rings, at least for the compression side.
I use Viton versus std. rubber.
Should be able to order thu local supplier. Have a machine shop cut the grooves for you.. Not much to it really.
I've got a cool head now, with the O-rings... works great! No leaks, no thick gasket.
If you can't find any.. I'd be willing to bet many motor builders could hook you up... Someone mentioned Trinity also does custom work on the stock head for O-rings.
(Not that I would trust Trinity)
1ArmBandit
55
Oct 14, 2015 09:03 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
