Changing oil, some questions.
Old Feb 7, 2003 | 10:41 AM
JeffP's Avatar
Default Changing oil, some questions.
First time changing the oil on the Z400. First question where is the oil filter located? Second question whats the recommended amount of oil that goes in. I picked up 3 quarts and a new Suzuki filter. Hopefully someone can answer these and save me some time this evening. I need to pick up a manual soon I guess.
Thanks,
Jeff
Old Feb 7, 2003 | 04:21 PM
KFXBob's Avatar
2 Liters of oil is right, a little more than 2 Quarts, drain both the crankcase and the oil tank, 2 drainplugs!
The oil filter is on the side of the motor, If I remember right, About 5 small bolts, and the cover comes off.
After you fill it up you need to run it for a few minutes so the oil gets sucked out of the tank into the motor.
It's a dry sump motor, so if it sits for awhile the tank can read low, but oil has drained back into the motor.
Always run the motor for a few minutes before you check level. Also DO NOT run the motor with the oil tank plug out, Heck of a mess. Yes I did that once on a XR650, the tank is in frame and you fill it up next to the triple clamp, blew oil all over the bike and me.
KFXBob
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
bigred20653
Sep 19, 2015 02:11 PM
