KFX400 adjust. (thanks alot I am getting more help from the raptor guys)
Old Feb 7, 2003 | 02:34 PM
FsT4WrD's Avatar
Default KFX400 adjust. (thanks alot I am getting more help from the raptor guys)
I cant believe not one response
Old Feb 8, 2003 | 01:30 AM
BarelyLegal's Avatar
Response about what?
Old Feb 8, 2003 | 06:12 AM
Ward660R's Avatar
I think thats exactly what hes talking about.
FsT4WrD, if you haven't yet, do a search on it, as many ways as you can. I remember seeing a couple guys complain about it and were looking into a new swingarm, for different geometery.
Old Feb 8, 2003 | 09:40 AM
badchad's Avatar
Fst4wrd - sounds like you need to adjust the rebound on your rear shock. I'm not familiar with the KFX400, but I'm sure it is basically the same as most every other. What you need to do is find the rebound adjusting screw (which will probably be located on the bottom of the shock) and adjust it. I'm not sure which way is increasing or decreasing rebound on your quad, but the manual should show how to do it. Just give it a few clicks and push down on your quad and note how much faster or slower your quad returns to normal ride height. After a little tweaking you should be able to get it dialed in so it doesn't buck you off! There's a lot more to setting up your suspension than just that, but that should help you out.
Old Feb 8, 2003 | 09:41 AM
badchad's Avatar
I saw you've been posting on other threads and in other forums about your problem and also posted the previous information there. I hope it helps out.
Old Feb 8, 2003 | 01:30 PM
lvegas's Avatar
Finally !! The shocking story of how to "Tune your Suspension" !!!
Click link below
Tune your Suspension Link
Old Feb 9, 2003 | 08:59 AM
Ward660R's Avatar
Thats a pretty good article. Thanks
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
yambam13
Jul 4, 2015 01:49 PM
