lt80 jetting help!!!
Old Feb 8, 2003 | 03:13 AM
Vision's Avatar
Default lt80 jetting help!!!
can anyone give me a idea of what size the main jet needs to be with a dg pipe and stock filter around 1000 ft above sea level.thanks
Old Feb 8, 2003 | 09:06 AM
Zoinks!!!'s Avatar
PM LT80 and he will probably be able to tell you!
Old Feb 8, 2003 | 10:31 AM
LT80's Avatar
LT80 Expert
It's hard to say.I dont see whay a DG pipe would require much of a change.It'd help if we knew how it was running.Is it blowing smoke bad?Sputtering from too lean?
If your just afraid to do damage,don't be. Install the pipe and run it. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 9, 2003 | 02:16 AM
Vision's Avatar
well the bike belongs to a friend of mine.he put the pipe on and said it would not run without the choke on he was right .so i took carb off raised needle up all way still i could not tell a diff.then i took main jet out an got drill bit just alittle bigger than hole drilled the slapped it back together runs perfect now except at wide open where it blubbers out bad.
Old Feb 9, 2003 | 11:24 AM
LT80's Avatar
LT80 Expert
Well I guess you need a bigger jet/drill then. [img]i/expressions/face-icon-small-happy.gif[/img]
I will offer to send you some jets. I have up to 110 or 115..That way you could have a few to try w/o having to buy them all to try.
If interested,let me know. [img]i/expressions/face-icon-small-smile.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
merryman
Sep 19, 2015 03:15 AM
