What is this LT230
Old Feb 13, 2003 | 01:54 PM
robnhouston's Avatar
Default What is this LT230
It should be an LT230G, 1986 model. But I'm not sure if it's a quadsport or quadrunner or what?
It has:
chain,
electric start
reverse
disc front and rear
light
Everything else you should be able to see from this picture:
lt230?
I'm trying to order some new rear plastic here:
Link to parts
Thanks,
Rob
Old Feb 13, 2003 | 02:13 PM
MalHombre's Avatar
whoa! that is one rough-lookin' quad but i'm pretty sure it's a quadsport.
Old Feb 13, 2003 | 02:25 PM
TomM's Avatar
It looks like a Quadsport. Im pretty sure all Quadrunners were shaft driven. It is pretty rough looking. I would replace all the plastic.
Old Feb 13, 2003 | 02:34 PM
IT's a beater alright but it still runs and gets us around the property and back and forth to the river bottom.
Some of the highlights are no back brakes, some front brakes, it now has some huge tires on the back that will coat you with one mud puddle. And my favorite, the left front tire has no valve stem and hence no air. The bead is stuck to the rim and the tire (orginal I think) doesn't ride flat. WE of course don't ride it hard, just a utility vehicle.
But you can go into the barn right now fire it up and ride.
Thanks for the quick follow up.
Rob
Old Feb 13, 2003 | 02:37 PM
stormnorm's Avatar
I have a 87 lt230sh bought new and still have it today...it has outward kick start, chain drive, hand clutch, reverse, front and rear disc brake. It looks identical to yours except mine is white and blue. Yours is no doubt a quadsport...the #'s could be lt230e...or...lt230se...or...lt230sge..."E" for electric start. The quadrunners had a slitghtly different front fenders and auto clutch with elec. start. hope this helps.
Old Feb 13, 2003 | 03:01 PM
ernest's Avatar
If it has an electric start it is a quadrunner. They never made the quadsport with an electric start.
Is it automatic clutch?
Old Feb 13, 2003 | 03:07 PM
stormnorm's Avatar
His has both electric start and chain drive. The quadrunner has very different front fenders than he does!
Old Feb 13, 2003 | 03:18 PM
ernest's Avatar
My quadrunner has a chain as do most and the same plastic. If his is an automatic clutch it's a quadrunner. Plain and simple.
Old Feb 13, 2003 | 03:20 PM
Oh forgot is is an auto tranny. No manual clutch.
Rob
If you look at the parts link you'll this fender also fits a:
Suzuki 230 LT230E Quad Runner 1987-1993 AND
Suzuki 230 LT230S Quad Sport 1985-1988
Just want to make sure I get the right part.
One more edit, looks like the rear fender is the same on both anyway.
Old Feb 13, 2003 | 03:29 PM
ernest's Avatar
Thank you. Like I SAID it's a QUADRUNNER. Electric start + Automatic clutch = QUadrunner. Kickstart + manual clutch= Quadsport HELLOOOOOOOOOOOO
This forum is sad when a guy who's owned a Suzuki for two weeks (me) is giving out correct information and all these Suzuki "gurus" are giving out the wrong info.
