160 power?
Old Feb 17, 2003 | 12:04 AM
rda's Avatar
rda
Default 160 power?
hi,
i am looking at one of these for trail maintenance, I was wondering how much low end power they have. I currently have an old atc110 three wheeler, I would like something with a little more power and suspension. the 160 is the only quad i have found that is as small as the 110, which is important due to the tightness of my trails (they were designed for my dirt bike)
I mainly want to know if this quad has a low enough 1st gear to allow you to crawl over things and get up small hills
Old Feb 17, 2003 | 03:46 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 160 power?
We had the old 160 with racks (new ones don't have racks, and are way lighter). Sold it to a friend, and it is still going strong after all these years. The 160 has a very low 1st gear, so it pulls pretty well on the bottom end. It isn't any powerhouse though!! It does ok out on the trail, but its performance is limited by its minimalist suspension. Remember that it has chain drive, so mud isn't its element, and the balooney tires make it a little tippy. In general, this is considered a bike for older kids.
Old Feb 17, 2003 | 09:09 AM
rda's Avatar
rda
Default 160 power?
thanks,
the 110 i'm riding now has no suspension at all! just the tires. size of the 110 is even smaller then the 160, i think it was designed for kids 8-15. in low range though, it pulls my 220lb carcass around pretty good, and it is small enough that i can go down most of my dirtbike trails. i have had it about 5 years, i just want something with a little more power that doesn't beat me so bad.
my dealer says the new ones still have the mounts for the racks, they are kinda steep though, about $400 for front and rear. the dealer has a used 2001 model for sale, it is pretty rough looking, they are asking $1799, I might try and talk him down to $1000
Old Feb 17, 2003 | 10:36 AM
risonite's Avatar
Default 160 power?
my daughter and wife both ride lt 160s. I had one myself 'til a couple of years ago. This is a great tight trail machine! Most larger utility style machines will have to work hard to stay with it. we've used them to pull small trailers and other atv's, but towing really isn't a strong point due to their light weight. If you need ALOT of low end, you can easily change the gearing. A weak point is the front drum brakes; also ,the stock racks are rather small. you may want to consider aftermarket racks.
Old Feb 17, 2003 | 10:43 AM
rda's Avatar
rda
Default 160 power?
thanks,
I did a search on the net looking for racks and didn't find any. do you know of anyone that makes them?
Old Feb 17, 2003 | 11:57 AM
Mudracer300's Avatar
Default 160 power?
my little cousin has one and it would easly keep up with my old artic cat 300 4x4 the only thing is, it is pretty tippy but im sure it will be no worse than your three wheeler
Old Feb 17, 2003 | 04:55 PM
rda's Avatar
rda
Default 160 power?
i noticed on the specs for this atv that it only has 5.3" of ground clearance. is this at the axle or under the frame? 5.3 sounds pretty low, my 110 has 9" under the frame
Old Feb 17, 2003 | 07:49 PM
Default 160 power?
im pretty sure its under the axle usually they measure at the lowest point which whould be at the sproket or the rear brake.
Old Feb 17, 2003 | 08:19 PM
rda's Avatar
rda
Default 160 power?
how much would a used one be worth? I know of 2:
one is a 2001, the rear tires are bald, like they ran up and down the road alot, it also has a broken front fender. they are asking $1599
there is one on ebay that the guy says he bought for his wife, she didn't like it, and it has only had 4-5 tanks of gas ran through it. it is supposed to be perfect the bid is up to $1275, and the reserve hasn't been met yet.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
