Jet kit
Old Feb 26, 2003 | 06:53 PM
Toyguy's Avatar
Default Jet kit
Hey for you guys that have installed the Dynojet jet kits on the Z, how did you turn the fuel off to the carb. I'm thinking of using some small clamps but I don't want to rip the fuel line. Any help will be great. Thanks
Old Feb 26, 2003 | 07:02 PM
RideRed420's Avatar
Default Jet kit
this isn't my department but,
doesnt your gas tank have a on off switch???????????/
Old Feb 26, 2003 | 07:08 PM
FsT4WrD's Avatar
Default Jet kit
You have to do it the hard way , when I pulled my tank a little gas started to come out I turned it to PRI and it stopped why I have no clue only lost about 20oz of gas , or once you pull the line put a screw in it to stop the flo
FsT4WrD's Avatar
Default Jet kit
There is no off switch because its vacuum injected
Old Feb 26, 2003 | 07:43 PM
LTZ's Avatar
LTZ
Default Jet kit
Just leave it in the on position and disconnect it. Being that it works off of vacuum it will not constantly flow.
Old Feb 26, 2003 | 08:37 PM
feelingood's Avatar
Default Jet kit
Leave it in the on or reserve position. The pri position will make the gas run without the engine cranking. The on and reserve position requires the engine to be cranking for vacuem to open it in order for the gas to flow.
Old Feb 27, 2003 | 01:01 AM
Toyguy's Avatar
Default Jet kit
Then after I pull the hose should I run the gas out of the carb?
Old Feb 27, 2003 | 01:21 AM
LTZ's Avatar
LTZ
Default Jet kit
There will be a little gas in the bowl. You can either drain the bowl with the little drain screw, or remove the four screws and let it seep out.
