Lt500r Quadzilla owners
Old Apr 28, 2003 | 06:13 PM
  #41
truckracer's Avatar
Default Lt500r Quadzilla owners
Sprockets made a BIG difference. We ride sand most of the time and I don't need top end speed so its about perfect. It will still outrun a piped & jetted Banshee in 100 yards so I'm happy.
Old May 1, 2003 | 12:29 AM
  #42
dirtgirl's Avatar
Originally posted by: Quadzilla1000
Thats one expensive toy you have there, when you water pump seat goes bad does it leak water or oil from that cover? Mine just started this weekend leaking oil from that cover but no water!???? [img]i/expressions/face-icon-small-disgusted.gif[/img] So i guess i will have to fit that now!
Mine leaks water.. So far I think I got that fixed for now... shhhhh better not say anything too loud something else will go bad..
[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 1, 2003 | 12:47 AM
  #43
dirtgirl's Avatar
[quote]
Originally posted by: truckracer
Originally posted by: dirtgirl
Is your LT an 87 or an 88 up?
Zillarider02's 87 has the Keihin carb, 60 pilot, 180 main, 3 clip from the top @ 900 ft altitude. The 180 is a little rich for safety sake.. This is with 40:1 premix. His carb is a 39 bored to 41.5
I run 62 pilot, 175 main, 2 clip from the top on the 89 Zilla. Both motors are ported quite extensively. My carb is a 41 pro series.
Oh, I might add there are 5 Zilla's in our riding group now.......
Cool! I have bumped it up to a 180 mainjet and it seems like it is running better, but it doesn't seem like it is totally right on the bottom end so I think now I get to fool with the pilot jet.. Thanks for all the great info!
[img]i/expressions/face-icon-small-smile.gif[/img]
OH BTW when I was in town Monday getting my tags renewed on my vehicles there was a guy getting an ORV sticker for his Quadzilla. He had it in the back of his truck... He said he had just bought it - it looked pretty ragged to me but it was cool to see another local have one... now there are 3 of us in this area, but I am the only one foolish enough to try to ride mine in the woods. One of the guys who has just started riding with me has one but when we all go riding on the weekends he always brings his 250R Honda.
Old May 1, 2003 | 12:50 AM
  #44
dirtgirl's Avatar
I am running a 15 tooth on mine but in the woods I am lucky if I ever make it out of 1st gear. think I am going to a 14 next.
Old May 5, 2003 | 11:02 PM
  #45
dirtgirl's Avatar
Well I guess I better get on the phone and call Tudor's.. I blew another base gasket Friday blew the front out of this one.. Had to make another one so I could go riding Sunday. I am getting good at redoing the topend... Took 1.5 hours to replace the gasket.
Old May 6, 2003 | 12:11 PM
  #46
Duneaddict's Avatar
That's one thing you'll be a great Zuk mechanic after you own one for a year or so.... HA!
Yep, try that spring steel base gasket... you'll like it. Mines been trouble free for over a year now.
How do the mating surfaces look? Sometimes the factory did a poor job of lapping the cases before assembly.
Got any new pics lately? I could use a good dose of therapy... and they really fit the Rx.
Old May 6, 2003 | 09:17 PM
  #47
dirtgirl's Avatar
the cases and the cylinder have all been machined. I don't have a problem with them blowing out until I am running some pretty high RPMs[img]i/expressions/face-icon-small-shocked.gif[/img]
I am getting good at tearing it down and reassembling it. Took 1.5 hours last time and that was teardown, making the new gasket, and reassembling it. I even had to remove the footpeg (which is a PITA on mine because it is stripped out and has a nut on the back side that is really hard to get to without dropping the skidplate) and side case because the rod came off of the powervalve and fell down in the motor. After I got it out and made the gasket I put it all back together and was test riding it an hour and a half later.
Old May 6, 2003 | 09:20 PM
  #48
dirtgirl's Avatar
Tudor's was out of those gaskets the other week so I used a Cometic just to get it back together faster. This time I made one out of copper sheeting and gasket adhesive it would have worked great, but the sheet was a little too thin and it still leaks a little bit. It is still holding up though... I think it will work until I get one from them. then I will pop that gasket in and fix it up right.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Ahtatu
Sep 28, 2015 12:14 PM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
