lt125 runs rough
Old May 1, 2003 | 02:34 PM
fcm's Avatar
fcm
Default lt125 runs rough
I have an 85 lt125 quad that has a rebuilt engine in it. It sat for a number of years with only about 15 min of run time on it due to a bad cdi box. I recently put a new cdi box on it and cleaned the carb and put a new primer on it and got it running. My problem is that it tends to run rough at partial throttle, and will idle really good for a while and then try to die when you go to take off (repeatedly). I put a new coil and plug in it, but the problem persists. I was wondering if the stator has any adjustment to it that may effect the run quality or if I should look at a total carb rebuild (anybody know of a kit) or maybe a combination of the two. Any theories or suggestions would be GREATLY appreciated.
Also, when I first started it up, after it hadn't run in about 10 years, the muffler had a lot of rusty dust blow out, which eventually cleared up. Could I have an excessive backpressure problem?
Old May 1, 2003 | 04:50 PM
DASHIT2K3's Avatar
I think u need to adjust the carb.thast ur prob.MAyb eu might need to reround the magneto?
SOLOLUCKY
Oct 4, 2024 09:09 PM
wannabe32
Jul 7, 2015 11:30 AM
gfl0224
Jun 27, 2015 06:52 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
