LT 500 & FMF pipe
LT 500 & FMF pipe
Tick, WD-40 is good but a LARGE hammer is better. Mine was so far gone when I bought it, that the rear-end wouldn't compress when you sat on it. The bolt was friction-welded with a little rust to boot. I soaked it and wailed away for a couple of days before it "fell" out. Champagne is good though.
p.s. watch your fingers
LT 500 & FMF pipe
Originally posted by: theTICK
Yes I have a LRD pipe, yes I want to sell it .................................................. ...........but also I am selling the 1989 LT500 with it. The LRD pipe is bolted to a LRD motor which I want to sell. The TICK is for sale as soon as I get my stock LT500 up to speed. Some parts are being swapped over to the stock Zilla, the stuff for my 325lbs a$$ (shocks and swing arm ). I found a good stock LT500 in Pennsylvania. Only this wrong is the swing arm bolt is stuck. The Ticks came out easy since I replaced the bearings and bolt last year. So if you want the pipe you must buy the Tick!!!
THANKS FOR ALL THE HELP, still trying to remove it. I am soaking it with WD 40 to loosen it up. Maybe I should use Chamagne it works on my wife! HA HA HA[img]i/expressions/face-icon-small-wink.gif[/img]
You shouldn't have any trouble moving the TICK... pretty clean/nice looking machine!
Regards,
LT 500 & FMF pipe
"Dirt Rider" (an offroad bike mag) recommends "Permatex 598 Ultra Black High Temp Silicone Sealer" at all exhaust joints. A higher quality pipe spring should go a long ways towards stopping leaks at the exhaust flange. Use the very heavy exhaust springs often found on stock snowmobile exhausts (the aftermarket ones are often weak junk). If the spring doesn't go on and come off very hard it is not the right one.
"Duncan Racing" appears to have one of the best exhaust clamps but, after you factor in shipping, it's going to cost around $50. TM designs makes billet exhaust seals that are custom made for each type of exhaust (since different brand exhausts have different OD's). I used a TM clamp for my last pipe/silencer and it worked well. I believe it cost between $25 and $35.
The PSI pipe for an LT500R is a POS! I had one before moving up to a Paul Turner pipe. Getting rid of that PSI provided me with the most noticeable gain in power to date! Even the porting, Powerjet, and VForce II reeds didn't seem to make as big of a difference! The only other mod that came close to improving performance as much as the PT pipe was a switch from the stock Mikuni carb to a Keihin 39mm PWK.
mrtidy
02-03-2016 05:00 PM
greg86hd
09-16-2015 12:32 AM
