help with a lt160 please
Old May 6, 2003 | 08:07 PM
arnard's Avatar
Default help with a lt160 please
Need some mechanical assistance with my 89 160. When the engine is cold it starts adn runs fine. However, if the engine is hot it will start and idle fine but upon touching the throttle it will immediately die. Any thoughts? I probably should just have it rebuilt but I do jnot want to sink a bunch of cash in it right now.
thanks in advance.
ryan
Old May 6, 2003 | 10:20 PM
prarieandraptor's Avatar
First make sure your air filter is clean. If you have taken the air box lid off or made and muffler mods then you need to rejet.
Old May 6, 2003 | 11:08 PM
arnard's Avatar
would that cause it to happen all of a sudden? It ran fine all winter and the past summer. I haven't changed anything on it in over 2 years. I have taken the airbox cover off to change the air filter and then replaced it. Does that help any? Also, to aid in it starting if I put the full choke on and blow into the carb vent hose it starts immediately. Does that mean anything to anyone?
ryan
Old Apr 29, 2004 | 04:00 PM
jonathonrice's Avatar
i had the same problem with a 160 and i got a hold of some bad gas
1.first drain the gas
2.then take the float bowl off the bottom of the carb and drain it
then buy some premium gas and get some drygas at wal mart
and mix in the tank
3.then your 4 wheeler should idle high 4 a while
Twin LT80's
Jan 6, 2020 07:25 PM
Bergmann
Aug 13, 2015 03:51 PM
bikedad3
Jul 2, 2015 02:15 AM
NYH1
Aug 15, 2012 11:31 PM
