lt250r break-in
Old May 1, 2000 | 04:36 PM
Suz250's Avatar
I have an 86 lt 250 that just had the top end and bottom end rebuilt. It was bored .080 over and has a new rod kit. Does anybody know the best way to break this motor in?????
Old May 1, 2000 | 07:38 PM
THEXOTIC1's Avatar
1/4 throttle shifting gears alot for 2 tanks of gas. then on the 3rd 1/2 to 3/4 then start opening the carb up 4 tank drain oil and change you should have no problems
Old May 1, 2000 | 07:42 PM
86Qracer's Avatar
Mix your first tank of fuel slightly rich, don't let it idle all the way down for about the first 5 minutes of run (keep RPM'S up SLIGHTLY!), vary engine speed for around the first 30 minutes or so, avoiding full throttle. Also after it cranks and runs for the first time,run it for 5 or so minutes, then let it cool for a few minutes, then run it about 10 or so minutes, then let it cool, then run it longer. Let it cool down completely, retorque the head and cylinder base nuts, and you're good to go.
From my experience, this method works well. Good luck!
Greg Coats
Petal, MS
'87 LT250R
'00 Rancher ES
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
donintennessee
Aug 19, 2015 02:22 PM
oregonrider
Mar 30, 2000 06:18 PM
Galt
Feb 17, 2000 03:56 PM
