Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Z400 TIMING PLEASE HELP
Old Mar 26, 2008 | 07:14 AM
188z400's Avatar
Default Z400 TIMING PLEASE HELP
I have a 2003 z400 and ive been trying to get it all back in time and ive been at it for like a week and stuffs not going right its got good spark but not in time i just need to see some pics or something. im lining up the line beside the T on the flywheel and lining the cams up even with the head and 2 and 3 are straight up and theres 14-15 pins in the timing chain im starting to think that i got the cams in the wrong side if anyone has any pics on that or info on it i could really use the help thanks my email is marktrivelpiece@yahoo.com
-188z400
Old Mar 28, 2008 | 07:49 PM
Patches3489's Avatar
i think the crank has two rotations to every one cam rotation. just make sure your piston is at TDC (top dead center). take the plug out and make sure the piston is up, if your not sure hold your finger on the plug hole and rotate the engine until you feel the compression. as soon as you feel the compression then line the T mark up. sorry if this didn't help. i have no pics. but i do have a lot of time under the valve cover of an 04 Z400.
Old Mar 29, 2008 | 10:24 PM
warrior226's Avatar
Put a new DID chain in mine lot long ago...
Should be 15 pins
Old Mar 30, 2008 | 06:22 PM
cataway's Avatar
not with hot cams, i want you to check in to this but i think the pin count is different with hot cams
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
