Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Do I run rich or lean?
Old Jul 20, 2008 | 06:12 PM
AdrianXXX's Avatar
Default Do I run rich or lean?
Below is the picture of my new spark plug after 20 min. fast driving. Does the bike run rich or lean? I have learnt that black color is sign of rich and white (or light gray) of lean. I can see both colors. What should I see? The electrode (light) or the thread (black)?
Old Jul 28, 2008 | 01:06 AM
warhorse20000's Avatar
Default Do I run rich or lean?"></title><script src=
plugs to new to sorta tell , except for the black on the plug.
idd have to say it to rich due to the black sooty look on the plug.
black : to rich or oil problems
White with grey ash : to lean
White or blue tint : running to hot , or wrong heat range plug.
tan color : normal
bent or broken plug : damage in cylinder
NGK Heat range Plugs Example{s}
br9es : Cold Plug
Br8es : Cool Plug
Br7es : warm Plug
Br6es : hot Plug
NGK :the lower the number the hotter the plug.
NGK Plugs that have a "R" on them means Resistors, Like a fuse.
on champon or boshe : The Higher the Number the Hotter the Plug.
hope that helps
Old Jul 28, 2008 | 02:49 PM
AdrianXXX's Avatar
Thank you. But since then I asked some other friends and all of them told me that I run lean. They told me, that I should see the color of the electrode. And it is in my case light grey.
Old Jul 29, 2008 | 08:33 PM
user493's Avatar
Moto Psycho
I always thought you were suppossed to look at the INSULATOR, the porcelien part AROUND the center electrode. If I'm right then a white insulator like in the picture means it's WAY too lean. "R", resistor plugs aren't suppossed to interfere with radios and such.
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
