Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
just wondering
Old Sep 11, 2008 | 09:48 PM
crazy old mudslinger's Avatar
Default just wondering
my clutch is bout as hard to pull as my brakes , is their a way to loosen it up , or just buy a new one
Old Sep 11, 2008 | 10:10 PM
Sidewinder500's Avatar
is it the cable or the actual clutch itself.... try pulling the actual clutch lever on the engine itself... if that moves easily it is your cable you could try spraying some cable lube down the sleeve of the cable
Old Sep 11, 2008 | 10:15 PM
thanks , ill try it tommorow
Old Sep 11, 2008 | 10:29 PM
Williebee's Avatar
Check your cable to determine if it's bad before you try an adjustment , the O.E.M. cables are coated with teflon/compound ; when it wears off they get stiff and hard to ingauge with the hand lever !
And the cable routing , sometimes after maintaince/repair work the cables can get bunchedup/tight causing them to become hard operate ; after that i would say the clutch !........
fredrikrosen
Oct 29, 2016 07:56 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
firsttimerider
Sep 20, 2015 09:07 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
