Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
which gas line / hose to use?
Old Oct 18, 2008 | 11:25 PM
spcamno's Avatar
Default which gas line / hose to use?
I am looking into replacing the fuel / gas lines and can someone explain which is better for our applications: black auto grade rubber hose (fuel grade) or those poly type use on go kart and other high performace applications?
Thanks
Old Oct 19, 2008 | 10:38 AM
eggenz7's Avatar
you the black. i know it will probably never happen but if you just somehow get a stick jabbed up in that direction the black hose will hold up better than the poly type. just my 2cents.
Old Oct 19, 2008 | 08:34 PM
spcamno's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: eggenz7
you the black. i know it will probably never happen but if you just somehow get a stick jabbed up in that direction the black hose will hold up better than the poly type. just my 2cents.</end quote></div>
Thanks eggenz for your post / reply!
I agreed with you and thought the same way too, I guess I will go this rountine.
Thanks
Alex G.
Sep 11, 2017 11:38 PM
Mar 21, 2016 06:30 PM
Sassinm1
Sep 30, 2015 04:23 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
