Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
cutting out
Old Oct 19, 2008 | 11:11 PM
motorhead_junkey's Avatar
Default cutting out
i have been doing alot of modifications and never had a problem with it cutting from quarter throttle to wide open It started with my last mod putting the 400 ex boot in place of the stock I also have a really big k&n 5 by 8 inches I have ran through the jeting and tuned my exhaust with the disces cause I have a ct pipe and nothing has made the cutting out any better the only thing I could think of is maybe the caburator cant keep up anymore with the mods any Ideas would be great Im new at this fourm so Im trying it out thanks.
Old Nov 10, 2008 | 12:39 AM
JBL's Avatar
JBL
Default cutting out
You might want to go with a bigger carb. Why did you go with the 400ex boot? Only used when people go with larger carbs. Try going back to old intake boot and you should not have any more problems.
Old Nov 10, 2008 | 06:43 PM
700 sportsman's Avatar
Default cutting out
are you sure its jetted right??
Old Nov 10, 2008 | 06:59 PM
Default cutting out
well the reason I went and got the ex tube is cause my friend has a ltz 400 07 and is running a pretty similar setup exept stock compression piston and he got his dialed in perfect before it was too much for his carb and I have the tuneble exhaust so if i needed to i could d tune the air flow to get the peak power out of the carb but i found out recently that his year quad had an upgrade on the carb mine is a bsr 36 and his is a bsr 37 just a tad bit bigger just enough so im looking for a keihin fcr 39mm carb and that should fix the problem I did get it tuned with everything to run decent a little lean but rideble thanks for the advice though.
Old Nov 10, 2008 | 10:35 PM
Doctorturbo's Avatar
GOT BOOST!
Default cutting out
Could be a lot of things but it sounds lean to me.
Old Nov 13, 2008 | 03:39 PM
petitecodiac's Avatar
Default cutting out
I agree, you've got to put in an oversized jet.
Old Nov 13, 2008 | 11:48 PM
Default cutting out
I have already been from a 165 main jet to a 195 main jet and everything between same as the pilot and the needle has been on every clip with every main and pilot from stock to a a 40 I ve spent hours and hours on jetting right now I have a 175 main 30 pilot 1and half turns out on the mixture screw and its running ok but still wants to cut out a little oh and the clip is on the 2nd slot i think its always had this problem but now that i opened up the air flow massively that its made the bogging and cutting out way more noticble only the bottom end though the top end raps hard and smooth even when I had the 195 on the main but the low end was horrible then so thanks for all the advice i appriecate it Im just going to keep tring new things until i can get my fcr 39mm curtis sparks carb
Alex G.
Sep 11, 2017 11:38 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Elkaholic
Sep 6, 2015 02:44 PM
