Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
80cc Grizzly light install
Old Nov 10, 2008 | 12:09 AM
ARCTIC HUNTER's Avatar
Default 80cc Grizzly light install
Trying to help a buddy install some lights on his sons Grizzly 80cc any idea's on how, I was thinkin of going straight to the battery and then wiring in the switch right around the pod area? good idea or no! it shouldn't interfere with battery charging should it!
thanks for the help
A-H
Old Nov 10, 2008 | 09:15 AM
95wolv's Avatar
A lot of the little quads do not have the stator capacity to run a light and charge the battery at the same time, if you use the light a lot, you may find the battery not holding enough juice to reliably start the motor all the time,especially if you use a 50 or so watt light. I had problems with a 30 watt light on my son's LT80 years back, worked great, but after a long ride, had to jump start him occasionally. Nowadays, with LED lights being so bright, you could put one of them on, the amp draw is very low, and would probably not affect the charging much at all.
JohnnySplat
Aug 6, 2015 12:07 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
