Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
trx250x motor
Old Jan 22, 2009 | 04:45 PM
mx360snow's Avatar
Default trx250x motor
when i got my 250x it started right up. Went down the driveway and it stalled. tryed everything and it wouldnt start up again. It is a race engine made by TC. I bought a new motor to ride it but want the race engine. What do you think is wrong with it. Thanks
Old Jan 28, 2009 | 09:35 PM
brian 68's Avatar
does it turn over? did you change the plug? spark? no aperant head leaks? no oil sepping out? if the motor turns over freely . put it back in and switch all the electrical part's from the motor you know run's. stator, pick up. coil .
Old Jan 29, 2009 | 06:53 PM
mx360snow's Avatar
It turned over, changed the plug, was spark and changed the cdi box. There were no leaks eather. All the electrical works because I ride it with the same electrical parts.
Old Jan 29, 2009 | 09:23 PM
brian 68's Avatar
not to be rudundant , in particular i was talking about the stator/ pickup, . do a compression test next, may have broke a ring , blown the head gasket, or to back up a bit did you check for intake leaks? running the same carb? also did you let it warm up good b 4 pulling down the drive? race motor? new piston , bore, cam's , timing chain , crank,? may have to order new gasket's take the top end off, and have a peak ,
Pehter
Oct 3, 2024 11:00 PM
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
