swap 230s motor into 230e, wiring issues!HELP
should be a piece of cake. mounts on the frame are most likely the same. the s motor only needs wires between the stator and cdi, coil, and kill switch to run. the e has other stuff for charging and for the electric start.
just swap the harnesses too its very easy...
oh and you will get a ton more responses if you post in the huge 230 thread under the suzuki forum...
JackOReilly
12-07-1999 09:12 AM
