Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Warn A2000 on 2000 yamaha big bear 400
Old Nov 2, 2010 | 08:03 PM
jcford72's Avatar
Default Warn A2000 on 2000 yamaha big bear 400
just got this four wheeler, and have been going through fixing everything.
Now for the winch, hit the switch and nothing. Checked that it is engaged, it is, and still nothing. Has a stock frame mounted butterfly in/out switch - disassembled, cleaned all connections and re-assembled and still nothing.
The wiring seems like a simple setup, neg and pos straigt from battery to switch, then two wires to the winch, marks on the winch are 1 and 2.
I've heard mention of a solenoid, but there isnt one here.
My question is, can I run a pos and neg straight to the motor on winch, and does anyone know which connection is which?
Thanks in advance.
Old Nov 2, 2010 | 09:53 PM
Mehoe's Avatar
You can run the positive and negative straight from the battery to winch motor.
Old Nov 3, 2010 | 08:54 PM
jcford72's Avatar
it took whe winch off the bike.
I tried running positive from bat to winch and nothing.
I took the motor apart, cleaned all contact points put all back together, and still nothing. Any threads anyone knows of to trouble shoot this would be appreciated.
Model is a2000.
thx.
Josh
Old Nov 3, 2010 | 08:59 PM
TLC's Avatar
TLC
Check if its on the warn recall first. Warn Industries - 2006 Recall And Replacement Notice: Contactor
Old Nov 3, 2010 | 09:03 PM
jcford72's Avatar
thx, checked and its not on the recall list.
Ean
Dec 19, 2022 08:48 AM
southbayman
Jul 24, 2015 09:30 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
