Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2002 articat 500 4x4 brak fluid loss
Old Jan 17, 2011 | 12:51 AM
TODD D's Avatar
Default 2002 articat 500 4x4 brak fluid loss
can't find a leak anywhere it blows fuses for the ecm its been doing this for years i just unhooked wire for rear brake light and the fuse blowing stoped what gives?
Old Jan 18, 2011 | 07:19 AM
rdeeno's Avatar
If you can't see the fluid leak, then I would suspect a caliper is leaking, just have to look harder. As far as the fuse blowing, if you are unhooking the rear light at the assy, then I would suspect that either the fuse is to small a value, or something is running at too high of a load in that circuit.
Old Jan 20, 2011 | 03:17 PM
07 400's Avatar
You should bend the foot brake that hit the switch for the tail light. this should take care of the fuse part.
Old Jan 20, 2011 | 03:21 PM
07 400's Avatar
on the foot brake where it comes in contact with brake light switch bend the tab so it does not push on switch so hard this should take care of blowing fuses
95wolv
Sep 27, 2024 12:00 PM
Alex G.
Sep 11, 2017 11:38 PM
Sw00p
Sep 24, 2015 02:50 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
