Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
98 Warrior won't fire
Old Jan 18, 2011 | 08:12 PM
Wheatley's Avatar
Default 98 Warrior won't fire
Hello, I have been reading a lot of post on here and seems like you all know your stuff. So here we go. I have a 98 yamaha warrior that has a new stator, battery, starter. Has good spark but just won't start. I have been wrenching and ordering parts but I am sure it is something silly but I can't figure it out. My cousin told me to check the key stock on the fly wheel. Said that will throw off the timing if that is bent. Is there truth to that? I can't get to it because I don't have metric allen key. So before I go buy a set I thought I would see if that was a possiblity. Thanks for any help in advance!!
Old Jan 19, 2011 | 04:44 PM
woodsidewarrior's Avatar
compression fuel spark if you have spark and fuel check for compression could be something as simple as a valve adjustment if a valve doesn't have any lash it may be open just a bit letting all of your compression go out the exhaust or back through the carb
Old Jan 20, 2011 | 12:43 PM
Wheatley's Avatar
I have good compression. My timing is off about 1/8th inch from valve cover to the fly wheel. I loosened the two 8mm bolts but I can't spin the one without spinning the other. It has always been hard to start. I think that was my issue all along then I lost spark. Replaced stator and now won't fire up. So thinking its my timing. But since I can't adjust my timing do you think that key way is bent? I just ordered a flywheel puller.
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
