Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Messed Up Brakes
Old Mar 29, 2011 | 02:21 PM
ryder133's Avatar
Question Messed Up Brakes
Hi I have a 2003 Yamaha Warrior and yesterday I just bled my back brakes and they where nice and firm and tight. But if you leave the pedal for 10mins then push it down it has no pressure untill you pump it 4-5 times then its fine unless you leave it. I tighened up the bleeder nipple and there doesnt seem to be and fluid leaking. Got any ideas?
Old Apr 5, 2011 | 08:40 PM
ryder133's Avatar
*bump*
Old Apr 5, 2011 | 09:28 PM
450kodiak's Avatar
Try bleading again but this time attach a suitable size hose to the niple then the other end of hose into a small container with enough brake fluid to have the end of the hose submerged .
Pump several times with nipple open watching for any air bubles coming out into container. Important to keep hose submerged.
Check reservoir fluid level from going dry while pumping.
Old Apr 5, 2011 | 09:46 PM
ryder133's Avatar
Alright thanks man I was just letting it drain though the hose into the grass.
Old Apr 25, 2011 | 05:36 PM
ryder133's Avatar
Ive tried bleeding them and they still lose pressure and gain pressure. Anyone have any other ideas (iam tring to stay away from buying a brand new brake system.
Old Apr 25, 2011 | 06:15 PM
450kodiak's Avatar
Your brake master may need a rebuild kit.
Old Apr 26, 2011 | 03:51 PM
ryder133's Avatar
Forgot to say that my brakes where fine, Just spongy so bled them and they where great but then this problem started to happen. Could it be a way I bled them? (Ive tried 6 times now but still the same problem)
Old Apr 26, 2011 | 07:07 PM
450kodiak's Avatar
Spongy usually means air in fluid.
While keeping hose end submersed in the brake fluid container,
open niple, pump brake pedal down but before releasing pedal close niple.
Do this a few times.
See if you see any air bubles coming out.
If it loses preasure after sitting,
you may as i said earlier , need to get a re-build kit for your brake master cylinder.
New seals and "O" rings and main spring.
They normally are not that exspensive.
You should be able to get them "after market"
Old Apr 27, 2011 | 08:34 PM
450kodiak's Avatar
Before getting a rebuild kit , check how thick your brake pads are.
If they are wore down that could cause excessive travel.
Joe454
Nov 20, 2020 01:19 PM
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
