Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Low compression on sportsman 500
Old Feb 10, 2012 | 10:16 AM
seanimo's Avatar
Default Low compression on sportsman 500
Hi I bought a 1999 polaris sportsman 500 the machine wouldn't start it had poor spark so I pulled the recoil cover off cleaned up the flywheel got good spark but still wouldn't start so I did a compression test only have 75 psi . I haven't messed with 4 strokes much and don't want to put alot lot of money in this machine (been out of work since july with a broken leg)
What are the odds it's just the valves need to be reseated ? Ihave the valve cover off and thinking i'll just pull the head check the cylinder bore.
I don't have a ton of money in the machine and could probably do ok parting it out.
any help would be appreciated ,thanks
Old Feb 10, 2012 | 10:30 AM
TLC's Avatar
TLC
The 500 has a automatic decompressing system, a regular compression test would not be accurate.
My 500 pulls starts easier then my 250 Moto 4 did.
Old Feb 10, 2012 | 01:37 PM
seanimo's Avatar
Default compression
Ok so how do I check the compression?
Old Feb 11, 2012 | 09:43 AM
TLC's Avatar
TLC
Not really sure, we have a 97 with 8000 miles on it that runs great. There was a post of one not starting until the guy clean his carb.
The only issue I heard of the 500 Fuji built motor is some times the exhaust cam lobe wears out, but the motor will still start but backfire out of the carb.
slowgsxr97
Mar 18, 2022 03:40 AM
Big bousse
Sep 26, 2015 10:42 AM
manuelrivera
Aug 8, 2015 04:34 PM
southbayman
Jul 24, 2015 09:30 AM
ghost civic
Jul 19, 2015 10:13 AM
