Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
1988 suzuki lt230E motor trouble
Old Mar 1, 2012 | 08:46 PM
banditbuggy145's Avatar
Default 1988 suzuki lt230E motor trouble
My custom built off road single seat buggy is powered by a 1988 suzuki lt230E. When the motor is cold, it runs great, but for some reason once the motor is warm, it wont idle. It sputters, and will die out if i dont give it throttle, but when i do, it runs perfectly fine. If it dies out, i can refire it but i do have to give it throttle. It does have a cobra exhaust on it, however i had to cut about a 4" piece out to fit it in my buggy. I dont know if the carb has been rejetted, and since i cut the piece out of the exhaust I havent adjusted the carb. Any ideas as to what i should do?
Old Mar 21, 2012 | 03:09 PM
thejunkman's Avatar
I would start by properly setting the idle mixture first, then start looking at the jetting overall. On the surface it sounds like your idle mixture is on the lean side as in general as an engine heats up jetting leans out. Watch my video to properly set the idle mixture screw (air or fuel) this will also help determine if your pilot jet is the correct size or not.
How to: Idle mixture screw adjustment - The Junk man
Old Nov 2, 2012 | 08:39 AM
Bodock's Avatar
Sorry to bump an old thread, but wanted to say this was very helpful to me.
I was just given an 87 LT230E that I am bringing back to life.
neo27ny
Aug 24, 2015 02:02 AM
Proud Father
Aug 19, 2015 10:08 PM
ltrmc02
Jul 22, 2015 04:50 AM
ghost civic
Jul 15, 2015 10:48 PM
bikedad3
Jul 2, 2015 02:15 AM
