Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
1994 Polaris 300 2x4 wont run when it gets hot
Old Jan 20, 2013 | 02:02 PM
twg1985's Avatar
Default 1994 Polaris 300 2x4 wont run when it gets hot
i just recently rebuild the top end and rebuilt the carb it runs perfect when its cold but when it warms up the motor gets louder and it shuts down but doesnt sieze up. Any suggestions? i might try to mix the gas and see it that does anything
Old Jan 20, 2013 | 08:58 PM
If you just did a top end only and didn't check the rod and crank bearings,this could be a problem area. When they run good cold,then lose power when warm it's either the piston's losing seal against the cylinder or you have some bottom end problems. Plus if you just stuck a new std piston and rings in the atv and didn't bore it out to a larger oversize this will happen almost every time. OPT
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
