Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Tow Strap Plow Set Up
Old Oct 15, 2013 | 03:45 PM
new atv guy's Avatar
Default Tow Strap Plow Set Up
Kawasaki 750 Brute Force
Warn AT 25 Winch
Synthetic Line
Hello
I am getting ready for the snow and trying to figure out how to use a 2" Tow Strap as many folks on here have used with great success. I'm sure I can get it on my drum but problem is the small plastic fairlead attached to the plow is only wide enough to accommodate small rope. I just replaced the stock roller fairlead with the larger "plow fairlead" so I guess I could affix the old stock fairlead to the plow to replace the small plastic fairlead? How have you guys been getting the 2" strap through the fairlead on the plow (I realize not everyone will have an extra fairlead there...)???
If I go with a 1.5" strap I might be able to squeeze it through the small fairlead but would that be bad to do (kinda thinkin it would...)
Last year I used the warn 50' line and it broke numerous times. Currently I have a new Amsteel 1/4 line x 10' so that should avoid the problem of burying the line. I kinda just know this line will part so want to be ready with the tow strap solution. Please help
Thanx!
Old Oct 16, 2013 | 05:24 PM
Okay I'll be the first to answer to my question. So I discovered the fairlead I'm takin about is only on Warn Plows and most plows simply have the rope and hook attach to the plow. Warn said if I don't use that rope guide I could raise the plow too much causing a lot of damage. Is that likely or common? If so how can I prevent raising the plow too much? Thanks.
Old Oct 17, 2013 | 01:16 PM
Yep. You can cause damage if you raise it too far. Mostly cable or rope snapping. It's just that you're pulling a frame up against another frame with a winch that's pulling at 1500-3000 lbs. of force. I just kind of went by ear when I heard a little strain on the motor and would let go of the winch switch. This led to 2 breaks in the cable. I got the Warn synthetic rope with the larger roller and that helped. The best thing I did was put on a magnetic switch that shuts the winch off when the plow is raised to a certain height. It came with my Can-Am plow setup. I mounted the kit's magnet on the plow frame and the magnetic trip switch on the quad where the magnet would make contact. Once it reaches a certain height it shuts off the winch. Made the last month and a half of plowing snow that much easier. My guess is that someone else must make a switch like this other than Can-Am.
shimanok2
Jan 29, 2016 07:37 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
