Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2 bent wheel replacement question
Old Feb 11, 2014 | 10:53 AM
CSen's Avatar
Default 2 bent wheel replacement question
I slid into a curb and bent 2 rims on the same side on my Z. (Snow slides are fun). The other side is fine. Is their an issue if I get just a new front and back and leave the other side as is. Or do I have to replace all 4. I'll be re-installing the same tires on the new rims so the overall height will stay the same
Old Feb 11, 2014 | 04:09 PM
Scooter86's Avatar
Knows Old ATV Questions!
I don't see any major issues with this, as long as you are sticking with a similar rim. If the rims are of significantly different weights I could see the machine pulling slightly to that side though.
Old Feb 11, 2014 | 04:43 PM
user493's Avatar
Moto Psycho
If the new rims have the same offset you're okay.
Old Feb 11, 2014 | 07:14 PM
CSen's Avatar
Good deal. 'll try replacing the 2 and see if it affects the handling and post it. Thanks
Old Feb 12, 2014 | 10:25 AM
TLC's Avatar
TLC
Do not replace anything until its broken. 2 rims cost half as much as 4. Just make sure they are the same dimensions hight ,width, bolt pattern and offset and are alloy if that is what the other side is made of. ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
kwackermann
Jun 24, 2015 10:18 AM
Stillonit
Jun 18, 2015 11:23 AM
volsgo30
Jun 4, 2015 06:07 PM
