Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
idles great
Old Oct 16, 2014 | 08:50 AM
jniteguy's Avatar
Default idles great
i have a kawasaki 220 bayou it has new top end compression is 140 psi set valves at .007 and .008 respectfully set timing and double checked rebuilt carb with after market kit which replaced all jets ultra sonic cleaned carb set air at 1 1/2 turns open checked plunger it moves when you move throttle and have needle e-clip in second from bottom notch replaced fuel line and filter cleaned pet ****. it starts right up and idles nice but as soon as you give it more then a 1/4 throttle it get boggy and runs rough has very little power i am at a loss could use any help thanks
Old Oct 16, 2014 | 12:35 PM
Other than double checking your work on the carb,check that the aftermarket jets are the same size as the oem jets. Should be able to read them on the side of the jets.
Old Oct 16, 2014 | 03:27 PM
jniteguy's Avatar
i will give them a look i am down to pulling carb again anyway thanks for the input
Cole Hadden
Jun 15, 2025 09:05 AM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
