Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Namura piston clearance
Old Dec 21, 2014 | 09:33 PM
Farmer_lesway's Avatar
Default Namura piston clearance
I have a 1996 polaris xpress 300cc 2 stroke. Stock piston is 74.5 mm bore, I am replacing the piston with a namura piston 20 thow oversize, 75mm bore, I need to know the clearance specs to bore out the cylinder and can't find them any where, the website is not very helpfull. If any one has any helpfull information on the piston clearance specs or can point me in the right direction it would be greatly appreciated, Thanks!!
Old Dec 22, 2014 | 12:37 AM
Manual shows piston to cylinder clearance to be between .0012-.0026. Service limit .006 When I bored and honed 2 stroke cylinders I tried to set them up around .0015-.002 final clearance. Always premix the first tank of break in fuel 50-1 along with using the oil pump. If you bypass the oil pump premix 40-1 with a good synthetic oil. A lot of piston manufacturers aren't suggesting any certain clearances just to protect them selves..
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
