Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Help with battery not holding a charge
Old Apr 2, 2015 | 05:24 PM
big_cigar's Avatar
Default Help with battery not holding a charge
Suzuki 2005 King Quad 700
After over a year of the dealer trying to fix my stalling problem. They thought they fixed it 3 times. I got Suzuki involved and they finally changed the throttle switch which did not show up as bad. That was the fix.
So I really don't want to bring it back to the dealer.
Just got it back with a pretty new battery and now it looses a charge very quickly. If I know what to look for I will fix it myself.
What should I be looking at?
Thanks
Bruce
Old Apr 2, 2015 | 05:48 PM
To start off with does the battery receive around 13-14 volts or so while at an idle? If not could be a faulty regulator/rectifier.If it is charging the battery may have an open cell and may not be able to hold the charge. Simple way on this is to have the battery load tested.It can tell you real quick if the battery itself is the problem.
Old Apr 2, 2015 | 06:14 PM
big_cigar's Avatar
If I don't have any gauges to test output and I assume it is the alternator, is that an easy fix? How expensive is the alternator?
Thanks
Bruce
Old Apr 2, 2015 | 06:46 PM
About 26 bucks here.Cheap meters are everwhere..http://www.ebay.com/itm/REGULATOR-RECTIFIER-SUZUKI-LT-A700X-LTA700-LTA700X-KING-QUAD-4x4-2005-2006-ATV-/281008563519?pt=Motors_ATV_Parts_Accessories&hash=item416d6a653f&vxp=mtr
Old Apr 2, 2015 | 06:59 PM
big_cigar's Avatar
thanks
checking if a buddy has a gauge and see where I am at.
Old Apr 6, 2015 | 10:48 AM
Zrock's Avatar
Super Quad Patrol
Do you have any accessories that you have installed . I had one of these indicators installed and after a year of fighting to keep a charge on the battery and a new battery i finally figured this was the culprit. Did not think something that small would drain the battery in 2 days
Comfort Indicator Eyelet M6
Old Apr 6, 2015 | 11:11 AM
big_cigar's Avatar
it has a winch but has been ok. My friend will come by with his testers and see if I am drawing power or if I am just not recharging the battery. Thanks
Bruce
bzdok1234
30
Feb 23, 2016 01:55 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
