Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
01 scrambler 500 carb ??
Old Apr 19, 2015 | 09:32 PM
My65coupe's Avatar
Default 01 scrambler 500 carb ??
Need some advice.
Can't get scrambler 500 to stay running replaced diaphram pump filter and all lines. Wanted to rule out all easy fixes. Will run with shot or starter fluid but idea when hit throttle.
What carbs are interchangeable for 500's.
Also found a carb on auction site that looks the same but for predator 500 2003-07 will that work for me.
Old Apr 19, 2015 | 09:58 PM
Carbs can be rebuilt! The BST40 Mikuni can be a bear to set the float level right,plus a lot of them do drip occasionally through the over flow tube even if every things normal. If you didn't install a carb kit,do thist first. Just cleaning carbs don't always work. Plus the float bowl holds the needle and seat in place.http://www.ebay.com/itm/Shindy-Carburetor-Kit-Scrambler-500-1998-2002-Sportsman-500-01-02-Carb-Polaris-/251691018048?hash=item3a99f42740&vxp=mtr Float level is critical on this and should line up parallel with the carb body while the float tab is barely resting on the small needle plunging pin.
Old Apr 24, 2015 | 08:38 PM
My65coupe's Avatar
Ok so have a update on carb issue. Got the rebuild kit replaced all but
The small jet couldn't get it out was stripped previously
So crossed fingers on that one.
Now it runs under idle can hit the gas all good
But when I put in gear and hit the gas it dies. I
Could it be the small jet is the carb trashed.
Old Apr 24, 2015 | 08:55 PM
Pull the black wire from the limiter module first and see if that helps. They're bad about shorting out and cutting spark even in forward range. Item #32 on the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse If that doesn't help then could be partially caused by the jet. A small drill and a small extractor can remove this.
Old Apr 24, 2015 | 09:06 PM
My65coupe's Avatar
Ok did as you said engine was cold so have chock it moved
So what does that tell you what should I replace
By the way your a freaken genius Thanks.
Old Apr 24, 2015 | 09:11 PM
NOT understanding what your typing?? If it runs ok with the wire pulled just leave it unplugged. You'll have full power in reverse without having to push the over ride button also.A new limiter module would just go out again.No sense in replacing it.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
