Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
1987 suzuki lt230s valve timing causing low compressing
Old Aug 17, 2015 | 02:19 PM
Mikegriff92's Avatar
Default 1987 suzuki lt230s valve timing causing low compressing
I just rebuilt this thing new piston rings got it fired up compression only 120 could that be adjust the timing by the caps on top of the head??? Will it boost my compress ion n stop smoke???
Old Oct 26, 2015 | 02:40 PM
230e's Avatar
No, taking off the covers won't Adjust the timing, you'll have to take off the valve cover on the top of the head. Also oil is only caused by a bad valve seal or piston rings. I would replace those while you're at it bc I did it and it was only a $30 job including rings seals and gaskets and it runs perfect now
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
ytailmt68
May 29, 2015 02:24 PM
kibby
Oct 8, 1999 09:23 PM
