Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Repeated Fuel Pump failures
Old Oct 18, 2015 | 04:28 PM
Tmims's Avatar
Default Repeated Fuel Pump failures
I am working on a 2004 Kawasaki Prarie 700 that sat for several years. I rebuilt the carbueretor, replaced the fuel lines, and then found a bad fuel pump. I replaced the pump and it started and seemed to run ok. A short while later, it stopped running and when I checked the new fuel pump, it was no longer pumping. I pulled the pump and tested it by directly connecting to the battery and got nothing so I ordered another. I put in the second pump and it was back running again. Unfortunately this pump now seems to be stopped. I was wondering about the voltage regulator and plan to test that next. What else could b causing these repeat fuel pump failures?
COFatboy
May 2, 2020 12:06 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
bafisher1986
Jul 21, 2015 04:12 PM
