Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Urgent help needed
Old Jul 10, 2016 | 02:46 PM
Notty1975's Avatar
Default Urgent help needed
Hi all finally got the quad wired up again and running properly took it out today for about 6 hours and it went well stopping and starting no problems went through a good puddle with mud and I'm not sure if I stalled it or it cut out but not can't start it with start button all I'm getting is clicking from the starter solenoid bump start it and it goes fine tried bypassing the solenoid and still nothing took some readings of the battery 13v off around 15 when running but drops to 3v while trying to start tried jump starting off a known good battery and still the same all I can think of is water got in the wiring somewhere and causing the problem but still can't work out why won't start when bypassing the solenoid and ideas would be great thanks all
Old Jul 10, 2016 | 09:05 PM
hydrex's Avatar
Pull out the spark plug and try it.
Old Jul 11, 2016 | 09:00 AM
Notty1975's Avatar
Thanks for the info mate got it running today of a jump start went through all the electrics again and found the rectifier was putting out way to much so I think that boiled the battery and killed it
toonces
Mar 14, 2016 10:42 PM
topkick857
Jan 27, 2016 09:10 AM
jeffreybandel
Jan 18, 2016 04:49 PM
ritchierich
1) Engine problems..
Jan 13, 2016 02:57 AM
tony
Sep 8, 1999 09:29 PM
