Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2002 wolverine no low end
Old Jul 26, 2016 | 01:38 AM
Eworrall's Avatar
Default 2002 wolverine no low end
Just purchased a 2002 wolverine 350 yesterday. It's in good shape and drives great with the exception of smoking a bit when really getting on the throttle. I pulled the front bumper up to a tree to try and spin all 4 tires only to find it not able to. When under load such as against a tree or on ramps into the truck, the quad has no power and bogs down and doesn't spin the wheels. Not sure where to start. Could this be related to the smoking? Just got it and haven't had time to mess with it, just curios what others thing it could be. Thanks
Eric
Old Jul 26, 2016 | 08:49 AM
hydrex's Avatar
Smoking is never a good sign. Does it foul the spark plug, start hard? Hate to suggest, but maybe going to a heavier oil might get you some more miles out of her, like a 20W50. Also, might play with the PMS screw, see if it runs better, try turning it in 1/4 - 1/2 turn , if it gets better, keep turning until you find the sweet spot. Same turning out, just don't go out more than 2.5-3 turns out.
Old Jul 26, 2016 | 11:02 AM
DirtDevil101's Avatar
I'd think about getting a compression test done and go from there...smoking from a thumper means crankcase oil is bypassing the rings...it might run decent without much load, but once you make that potentially tired engine work, well, you get what you got...
Old Jul 26, 2016 | 03:17 PM
Eworrall's Avatar
What is the pms screw and where is it located?
Old Jul 26, 2016 | 03:59 PM
hydrex's Avatar
Pilot Metering Screw. Small screw on bottom of carb, close to the cylinder head side. Effects the A/F ratio at idle and slow speeds. A dirty or partially plugged pilot jet will make it run like crap, too. I'm hoping it's not worn out, but a compression test would be the best bet.
Old Jul 26, 2016 | 04:31 PM
Eworrall's Avatar
That's the weird thing. It runs perfect. Starts perfect. But under load it just bogs down. Most likely will do rings at least because of the smoking. Smells like burnt oil
Old Jul 27, 2016 | 11:58 AM
At idle or putting around the load on the motor is minimal and thus the impact of horsepower loss is also minimal...that changes as you place more demand on the engine...so it's running perfect under no-load conditions...you want it running good under high-load conditions...
The A/F screws really won't impact at WOT as you are on the main jet more than anything else...generally they are idle mixture screws...
suzuki230
Jul 8, 2016 10:03 AM
Dirtrider74
Jul 7, 2016 12:50 PM
Whitelx1
May 18, 2016 03:48 AM
MNatv89
Mar 11, 2016 03:25 PM
Snky
Feb 8, 2016 07:13 AM
