Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2000 Expedition 425 Speedometer bypass
Old Jan 13, 2017 | 09:41 AM
Zig28's Avatar
Default 2000 Expedition 425 Speedometer bypass
No 4x4 speedometer was missing when I purchased .These are the wires coming from speedo r/w. brn gry/w y/r. gry .Do I tape two of these together .Or do I ground 1 of these.No brn/w coming from speedo.
Old Jan 13, 2017 | 12:21 PM
Ground the brown first and see if that helps.If it doesn't, ground the Gray white to it. On. Some older models hub grounds were Gray white. Look to see what color wires are coming from the awd coil.
Old Jan 13, 2017 | 03:27 PM
Sorry was trying to use my phone earlier.. Brown/white is the awd ground. You can jump it to the brown wire if you still have the speedo connector harness and you should have ground.Or jump it to any other brown wire or good frame ground.This would bypass the awd ground going through the speedo if you had one. Gray is the power wire to the hub coils.
Old Jan 13, 2017 | 03:58 PM
Zig28's Avatar
Default 2000 Expedition speedometer bypass
There is no browm an white wire coming from speedometer.There is a red an white a brown a gray an white a yellow an red and a gray.I think the brown is a ground .The gray goes to the hub coils .I read the somewhere a guy said the gray wire going to hubs are ground.If the gray is ground can I put brown an gray together an ground to frame.Don't what to fry anything.
Old Jan 13, 2017 | 04:54 PM
Yep you're right when I looked on the wiring diagram. On the 2000 Expedition the brown/white didn't go through the speedo like most of the other models,but it is still the awd ground wire. Any loose brown/white needs to be grounded either to a group of browns or a good frame ground.Or you can do as many have done on the 500's and go straight from the hubs.
Gray wire does come out of the speedo connector and it has to have voltage to the hubs. On that you may have to jump it to the red/white(powered up with key on) from the connector and possibly use a toggle in between if you're not going to replace the speedo.
