Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2001 sportsman 90 compression loss
Old Dec 23, 2017 | 10:47 AM
Shootenbulls's Avatar
If I decide to go premix oil I don't have to put it back, but what about the snap ring and pin?
Old Dec 23, 2017 | 11:29 AM
Originally Posted by Shootenbulls
I looked all over the internet for that tool and had 0 luck. At about 2am I gave up and used channel locks to remove it.
Probably what I did but can't remember..
Old Dec 23, 2017 | 11:34 AM
Snap ring I'd reinstall.The pin I wouldn't worry about. Make sure you block off the oil injector nozzle on the carb.You can get plugs at most auto stores.
Old Dec 23, 2017 | 06:07 PM
Could you recommend a 2 stroke prefix oil that I can get at the parts store?
Old Dec 23, 2017 | 06:41 PM
  #15
Man tha's like what's the best engine oil.. Don't want another debate. ANY major brand,synthetic preferred, 2 stroke premix oil designed for cycles,atvs. Just do a google search and your head will spin...https://www.google.com/search?q=2+st...h=745&dpr=1.25
Old Dec 23, 2017 | 10:05 PM
  #16
Ok I swapped the seals, and no change. Thats 2 different new jug kits, a reed valve, and seals. Im so friggen lost. Still 58 psi!!!!!
Old Dec 23, 2017 | 11:18 PM
  #17
user493's Avatar
Moto Psycho
The last 2-stroke oil I bought was TC-W3 rated Pennzoil Marine Premium Plus and I don't have a boat. I was told it's good for all 2-strokes, but if I was getting something for an ATV instead of a smaller engine I think I would find a full synthetic instead of a blend like that.
Old Dec 24, 2017 | 06:36 AM
  #18
Then the leak down test is what you're down to. New seals would seal the lower end,but if it's leaking at the engine crank case inner web area, seals aren't going to help. Plus 2 different top end kits,showing the same compression.. Under about 7psi on the leak down tester,open the oil fill plug and check for air leakage or bubbling in the gear case section,plus spray soapy water around the outside of the crank case seam. If you find bubbling either internal into the gear case section or leaking around the crank case section,the engine will have to be split,cases cleaned,resealed.
Attached Thumbnails 2001 sportsman 90 compression loss-e53cb8daae67f9de13c8a664c295b0f928b2b5f5.png
Old Sep 8, 2021 | 01:01 PM
  #19
ACmoto's Avatar
Default Exactly the same issue I'm losing my head please help
I couldn't find bubbling anywhere
  #20
ACmoto's Avatar
Default Any updates
Any updates
